S SolarHelperMN New Member Joined Nov 2, 2021 Messages 3 Nov 2, 2021 #1 Problem solved. Thank you for the help Last edited: Nov 2, 2021
NVS Solar Enthusiast Joined Sep 14, 2021 Messages 372 Nov 2, 2021 #2 It looks like your temperature sensor went bad it is showing -40C. Go into the settings and turn off that sensor by changing the 1 to a 0. Then you should be good to go. You'll have to order a new thermistor to get this function back.
S SolarHelperMN New Member Joined Nov 2, 2021 Messages 3 Nov 2, 2021 #3 solved Last edited: Nov 2, 2021
MisterSandals Participation Medalist Joined Nov 5, 2019 Messages 10,081 Location Silicon Valley Nov 2, 2021 #4 How about disconnecting the temp sensor and power cycling the unit? It doesn’t need a temp sensor to operate. I would definitely replace the temp sensor if there is a freeze threat.
NVS Solar Enthusiast Joined Sep 14, 2021 Messages 372 Nov 2, 2021 #5 Wow, not going to tell us what fixed it?
S SolarHelperMN New Member Joined Nov 2, 2021 Messages 3 Nov 2, 2021 #6 I removed the posts because it wasn't my info and I didn't know if any of the screenshots showed anything it shouldn't The fix was plugging the temp sensor back in. Apparently the cable had come unplugged. Thank you everyone who helped
