Pete in Puerto Rico
- Aug 11, 2022
- 29
Hey guys, I'm trying get the setting correct before I turn on the inverter. Looked at the official video for the setting from EG4 gave me no real info. I'm using Chins 12.8 v LIFePO4 200 ah batteries. I am puting them in series to make 2 - 48v batteries. The battery banks will be wired to a busbar before going to the inverter. The issue I need help with is 11 and 12 in the settings. Should I use SOC or VOC. What value should I be looking for.
Here is the battery info:
Charging Limit Voltage: 56.8V
Over Voltage Disconnect Voltage: 58.4V
Over Voltage Reconnect Voltage: 55.2V
Float Charging Voltage: 55.2V
DischargingLow Voltage Disconnect Voltage: 46.4V
Low Voltage Reconnect Voltage: 49.6V
Under Voltage Warning Voltage: 51.2V
any help is much appriciated
