JohnAdams1
I contacted Power Queen after purchasing 4 LiFePo4 batteries and wanted to know the parameter settings in a MPP Solar LV 6548. Here is their response to my question.
Bulk Charge Voltage -- 58.4V
Floating Charge Voltage -- 55.2V
Low DC voltage cut out -- 43.2V
Low voltage reconnect --- 49.6V
Over voltage disconnect --- 60V
Over voltage reconnect --- 56.8V
Battery equalize voltage -- Disabled or 57.6V
Battery equalize time -- 5 mins
Battery equalize time out - 5 mins
Equalize interval -- 0 days
{I also asked about adding 4 more in series for the 48v placed in parallel to the first set}
Maximum Discharge Current -- 100A (And will be 200A once you added additional 4 units)
The total maximum discharge watts 5120W (And will be 10240W once you added additional 4 units)
