We have had an off grid cabin going on 21 years. I started in 2003 using a Trace SW5548 inverter with 8x Trogan T-105 batteries and 8x 60w solar panels plus a Trace C40 charge controller. After 6 years the Trogans were done, so I located some even larger locomotive batteries from Dyno Batteries here in Seattle. These massive 2.2 volt 500 ah have served us very well for 15 years as I never abused them for the first 10 years but the last 5 have seen them dipping well below the 45 vdc minimum voltage desired.
So now it is time to break into the new age of LiFePO4 batteries. I am looking at 16x 304 ah units from the 18659 Battery Store. I am comfortable in wiring these all up but I am not understanding the sizing of the BMS. My SW has a 5.5 kw inverter so the input could be >100 amps. OK their JK BMS B2A24S15P is rated at 150 amps continuous but I do not understand is the need or the sizing values for active balancing. Is 2 amps better than .6? Is active balancing even desired or needed as some Daly brand BMS units requires an additional components?
We use the cabin 2 weekends per month on average (more in the summer and less in the winter but do enjoy the wilderness year round) so there can easily be several days if not a week or more that we are not there. The biggest hitter is out 1/2 hp shallow well pump and then the occasional power tool. I have upped the solar collection to 1200w and we have a Yamaha 6600 genset for bulk charging if needed.
Moving forward I will be updating the charge controller to a mppt unit and do plan to top balance charge these LiFePO4 batteries before installing. I have created a battery location that will maintain temperatures above 32 f except maybe for the 2 crazy 15 below days we experienced last month.
Once this system is up and running I have the additional desire to move to a LiFePO4 100 or 150ah house battery for our 87 VW Westfaila but for now we need to get the cabin setup and running.
TIA
TIA
