Sounds like bs unless they can show a working prototype that is independently tested
The company has completed a proof of concept, and is ready to begin building its commercial prototype once its labs reopen after COVID shutdown. A low-powered commercial version is expected to hit the market in less than two years, and the high powered version is projected for five years' time. NDB says it's well ahead of its competition with patents pending on its technology and manufacturing processes.
The physics is solid. It's quite clever and possible.Sounds like bs unless they can show a working prototype that is independently tested
Depleting the battery removes the waste through beta decay. It seems to me that you'd be able to put many cells in series to make a large bank, similar to what Tesla does now.We will probably never see big batteries on the market, since radioactive waste would be a real problem.
actually you do not need to deplete the battery.
radioactive material is depleting itself (tritium for example loose half power every 12.5 year).
the problem is if you take tritium, after 12 years, you still get the same battery weight but only half the power.
and after 25 years, you get a brick that can hardly power the device it was designed for.
So you would say , it is easy, take a radioactive material that has a longer half-life.
plutonium 244 has a half-life of 80mio year.... and some other isotopes of plutonium have "only" 7000 years.
but then you get a problem, what do you do with a waste battery, if the radioctivity will sitll last 200 mio years ?
you need to build a pretty solid one to work for decade before it reach its half-life.
after that the battery would not offer a ratio energy/weight that is interesting.
You already have carbon-14 in your body.And we think LiPos are dangerous....
They are actually a thing, and have been for a long time. They aren't going to change the world, the power production is extremely low. Fine for running a pocket calculator, fine for running a LCD wristwatch, fine for any application where you need very very low power (microwatts) over an extended period. Running your car? Not in a million years.* Not a guarantee that it's not vaporware, not infeasible, or not too expensive to consider. Still, it may yet be tested by the market.
