turbineinfo
- Apr 29, 2022
- 7
My set up:
Three 200 watt Renogy panels in series
One Epever Tracer 4210AN charge controller with MT50 display unit
The Epever is set to the default LFP04 battery type
One Chins 200ah battery, 100 amp BMS
One Xantrex 2000 watt inverter
I live in Southern California and get a good 6 hours of sun in the summer
Observation:
At 12 noon, in full sun, the MT50 shows (what I understand) a 12.9 input voltage (see attachment)
In order to bump up the input voltage, I have to turn off my inverter, disconnect my solar panels from the charge controller, count to 20. Then I reconnect the solar panels to the controller.
I leave the charge controller turned off.
After these steps, the MT50 displays a input voltage of 14.6 (see attached).
It seems unnecessary to go through the above steps.
Can someone please explain what I am observing?
Am I resetting the battery BMS?
Is this typical behavior of Chins batteries? is this a common occurrence ?
Is there an glitch in how the charge controller interacts with the battery?
Observation:
