Hello all,
I am getting a new caravan and want to upgrade the power system in it as soon as it arrives. I have previously installed a DIY LIFEPO4 solar system in my existing caravan (link here, if you are interested) but this time I am going a little more "off the shelf".
I want to have enough power to go off grid for at least three days in cloudy weather. The load will be LED lighting and charging small devices, as well as a few fans. The fridge is 3-way so won't use any power when the caravan is not plugged into the mains.
Here is a diagram of my initial plan:
The current sensor connects to the EasySolar system and helps it to monitor incoming power.
The fridge is connected to the non-critical outlet on the EasySolar system, so that it is not supplied power when the caravan is not plugged into the mains. I will use a relay to switch it on and off, because the factory fuse and distribution box in the caravan is hard to change and I want to avoid having different fuses if I can avoid it.
I have decided to go with a 24V system to keep current more manageable between the battery and the EasySolar system when running on the inverter, this means I have to use a DC/DC converter to drop the voltage down to 12V for the lights etc.
I like the EasySolar system because it is an all-in-one system (nearly, anyway) and I can use the 240V outlets regardless of whether I am plugged into the mains or not, the system switches between it automatically.
I plan on wiring the panels in series, because in NZ it is more likely to get cloudy weather than partial shade on the panels.
This will cost me about NZ$5,000, not including the panels (they are already installed).
I welcome any advice or suggestions!
