Hi,
I'm looking for solar devices (charge controller, inverter, power optimizer) that should be build on transistors (instead of diodes), leave the reasons why.
I've check the manual and technical spec of some products (around 5) and none of those documents contains the internal structure detailed as I need.
How can I this particular info of solar device? is there any website or even someone who know this staff and can answer?
To summarize, I'm building a solar solution that contains only transistors based components (at least the DCDC converters).
Thanks
Thanks
