newsolardude
- May 10, 2021
- 7
Hi all,
So I recently set up a off grid system:
x4 210watt solar panels connected in parallel series (53V, 16A)
Makeskyblue 60A 12V MPPT
Krieger 1100 Watt 12V modified sine inverter
4s 3.2V 100Ah LiFePO4 with Daly 4s 12V 100A BMS
The MPPT has a preset LiFePO4 setting which has an max charge of 14.6V and has been working fine. However, there are times when the battery is 100% charged and the inverter would continuously beep displaying a high voltage error. However, the inverter would continue to work and none of my breakers trip. I've recently been using the inverter's USB charging ports and during the high voltage error I see some smoke coming from the USB cables (or possibly the USB outlet).
I'm wondering if inverter USB ports has mechanisms in place to maintain a 12V charge? For example, if my LiFePO4 system is providing 14.6V, will that USB outlet charge my device with 14.6V or 12V? The inverter instruction manual only has the following details about the USB ports:
What could be causing the inverter smoke? Everything is still working fine, I've tossed out the USB cables but I want to make sure the problem isn't with the inverters.
Thanks
Two USB Ports (2.1 Amp shared): Allows the user to power one or two single 2.1A-compatible tablet devices or two 1A USB-charging devices, such as cell phones
Rates Output USB (V,A): 2 * 5V/max. 2.1A (iPad)
Thanks
