kolek
Inventor of the Electron
- Sep 29, 2021
- 868
Say you need to do some work on your inverter, in this case, connecting inverter to grid for the first time.
You switch off your PV inputs. Then you switch off the main DC breaker to disconnect your battery from the inverter. This should cause the inverter to bleed down the capacitors before shutting off due to lack of power.
Would it then be safe to work on the grid and load connectors on the inverter, or could there still be full capacitors on on the terminals that could shock you?
Maybe do a voltage check on the terminals before working on them?
