JoseAgustinV
- May 1, 2020
- 77
This is normal: if you check your screen display when the battery is about to full charge, it will go to max bulk charge voltage very fast (should be like 14.1-14.5V depending on unit settings), then it will drop to float charge voltage which is usually 13.5V, it is normal that the screen will display 13.5V at full charge @Dave1I’m experiencing the same symptoms. 13.5v max at the PIP display and volt meter at PIP / battery connection. My Battery Go BG-8s says 13.2v. Battery is Lifepo4 12v Sinopoly. Now 13.5v is 99% charged so?
