Greetings to the forum,
I just finished my first solar system, nothing fancy, specs below. Mostly built use for camping and running Ham Radio’s and laptops for logging but I figure it can come in handy for basic needs during long term power outages too.
Specs:
Epever Tracer 4215BN with the MT50 interface.
GoWise 3000 watt inverter (intentionally oversized)
Battle Born 100ah x 2 (2 more in the works)
Rich 100 watt panels x 6
So here is my question…running a test with a 1000 watt radiant heater (actual consumption 960 watts per clamp on ammeter and ohms law) I a watched the MT50 interface. I never saw the PV watts go above 425 watts. With the heater on it basically pulled 425 watts for maybe a minute and then dropped into the 250-300 watts and held there. The battery icon started dropping, and dropping and dropping indicating that it was pulling the majority of power from battery power instead of the PV array.
I do not have the inverter connected to the "load" connection on the charge controller. I am wondering, if I changed that, does the controller have the logic built in that would draw the watts it needs from the PV array first and balance the rest from the battery? Obviously electricity is stupid and does not go where I want it. (I am being a wise guy). I surmise what is going on is that the inverter has a higher resistance than the batteries so the charger is putting what it can into the batteries based on the charging profile. Yes, no?
Simply stated, I guess my expectation was that I could run AC devices during the day and as long as I was not exceeding the max input of the array/ charger I would not be drawing the batteries down. Am I wrong or is there something else going on here.
PDF of how I wired stuff up with oversized wire since I had a bunch of welding cable. I am getting about 56-64 volts depending on sun, and should get 600 watts, or thereabouts.
PS...great site but there is an overwhelming amount of information to wade through.
Specs:
