I'm not sure which iCharger model you have looked at. I own the iCharger X8.
I can't give you any good comparison with other equipment. However, I did shop around and chose the iCharger because it is sort-of a Swiss army knife of buck / boost charging. It has profiles for many different chemistries. It can charge or discharge a battery while measuring amp hours. It can bring a battery up to a preset voltage and then stop charging. The constant voltage phase of the charge cycle has an adjustable current cut-off setpoint.
You mention that the one you looked at has 20A per channel. I'm not sure what that means. When it comes to balancing, mine is limited to 2A balance current, but it does some resistance compensation to help make the balancing accurate. However, there are BMS and dedicated active balancers that also do 2A balancing as long as the voltage difference is high enough.
As far as total charge current, the iCharger X8 is limited to 30A or 1100W, which ever you hit first.
So far I have only balanced cells for a 12V LiFePo4 pack with it. I did so by setting the iCharger to 3.6v maximum and a 3.0 amp end current. Then I used a cheap 40v 10A max power supply to power the iCharger. The iCharger then converted that power to 3.6v at 30A. This let me top balance the pack with the cells wired in parallel much faster than turning the 10A power supply down to 3.6v and using it directly.
I've also used the iCharger X8 to test individual cells. If you use a battery as the power source, you can charge the cell using power from the battery and then discharge it from the cell back into the battery, both happening at 30A. If you don't use a battery, then the iCharger can only use its internal resistors to discharge the cell, and it is much, much slower. Anyway, during the test, the iCharger can log the data to an SD card if you want to see the charge/discharge curve, and after it is done, it reports the total amp hours on the screen.
Anyway, all I can tell you is that I'm pleased with mine. Hopefully someone with different equipment can provide more information for you.
