ulidtko
- Sep 6, 2020
- 4
Hi everyone! Another first-time poster here.
I'm trying to get through the planning/design phase of my first solar system. For the batteries, I really like and admire what people do with those hundreds of 18650 — however, for a first build I'd prefer something less involved and simpler. So to say, I want to first see a working solar system, test and "feel" its strengths & weaknesses — before embarking onto the journey of custom-built packs. You gotta keep your "helloworld" ambitions sane![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm soft-decided on LiFePO₄ chemistry for that reason (added safety + longer service life matters more to amateur me than top-notch capacity).
By a good chance, I can get 4× 12V 50Ah cells (ehhh, batteries, these should be 4S LFP cells internally) locally for about $900. Is that price any good, isn't it?
Although many reviews report there's protective cut-off circuitry built-in — no information yet if there're balancing circuits inside those 12V packs. I'm still undecided which overall arrangement (4S, 2P2S, 4P) to use, but should I pick the 48V 4S — I'm certain I'm gonna need a BMS.
Here's where I'm getting to my actual question. In LFP BMS's, the balancing wires are set nominal 3.2 volts apart — but I'll only have 12V-spaced inputs. Can I leave 3/4 of balancing wires unconnected? I'm sure BMS should be able to tolerate 1 or 2 cell dropouts — but not so sure if a 16S BMS will run smooth on only 5-wire connection (GND, +12V, +24V, +36V, +48V, skipping 3 leads between each).
Couldn't find this question even stated (lest answered) anywhere, including this forum — so doing it the old-fashioned way, asking myself.
Advice appreciated, and thanks in advance for any response.
