Rapidrob
My 6 month old ISDT Air8 will no longer charge my 39120S batteries over .1 that is point one amps?( 12 volt pack ) I have the charger set to 1 amp charge to give the cells a longer life and now it will not charge over .1 amps.
Every thing is hooked up correctly and I ran the battery pack for 5 hours today and my load indicated the battery was low and it was at 11.80 VDC.
The Air8 started at 1 amp and then dropped down in a couple of seconds to to .1 and has stayed there.
Moving the setting on the charger to a higher amp load does not help. The charger is showing a 13 hour charge time.
Please help.
Please help.
