Hello. I run the GModusbus and this is the result.View attachment 135433
I want to mix AC with PV if possible. If not I think i am going to sell the inverter.
I dont knowIt's an SMX 5.6KP ? so parralel version ?
Yes I can see that on the screenAccording to the reading of the modbus registers it would be a version 2.08 with a boot loader 2.01. Can you see that on your unit's screen?
No I dont. I dont have other firmware.I don't know the default version for the 5.6KP model.
Have you done a firmware upgrade?
I have a 5.6KW with 6.17 firmware. According to my various readings I think that it is not possible to make a real mix of AC and PV inputs with an EAsun SMX. I haven't tested it myself, I could be wrong.
Hello.Izolátum-SMX-II-5,6KP
Hello.
I have this, but I haven't dared to update it yet
Let me know if you've updated it.Thx.Isolar-SMX-II-5.6KP
No origi firmwareA word of advice, before upgrading, make sure you have the correct firmware as well as the original firmware to be able to roll back if necessary.
No origi firmware
Unfortunately, I haven't found it yet.
Inverter 5.6 KP Sent software for seller 6.35 mixload. It was not recommended to upload it here in the forum. Original for me soft 2.08. bootloader2.01. (date 2022.09...) If I had the original, I would post it immediately on 6.17 or 6.35 .You have to ask the seller.
It's also a 2.08 version for 5.6KP ?
I don't need a parallel option. Batteryless mode, which should be used, or to mix the pv input. According to the seller, it mixes the 6.35. I'm afraid it won't turn on after soft. In the absence of original software, I will still consider updating.I think you should stick with 2.08 and use your AIO with a battery.
There is a risk of bricking your AIO or losing the parallel options with 6.35 and maybe also 6.17 (5.6KW) but if you want to experiment why not, I would have liked to be able to do it on a test unit but my AIO is in production and works fine for me with 6.17 so I don't change anything.
as a result - returned to the old firmware - 6.17
The question remains - can the inverter mix panels and mains
Hello. ISOLAR-SMX-II-5.6KP. I installed the 6.35 mixload software. Parallel options plus or 10 menus disappeared. Wifi does not connect either. Works without a battery. Mix the network with pv.Hello. I run the GModusbus and this is the result.View attachment 135433
After reinstall wifi datalogger and 2 reboot inverter works wifi. ThxHello)
I have 6.35 Worked with WiFi.
You may need to reload the logger. I'm currently txting firmware 63.3
Hello. In the topic. As described in the second post. Sleeper85 .(wifi unplug)Hello. Can you tell me how you did the sofware update? What program did you used, what are the steps? Thank you.
