ExoticIntent
- Sep 11, 2022
- 11
I have a JK48V100PRO which I am trying to connect to my LV6548. Before I can do that, I need to change the inverter protocol setting in the BMS to "Pylon 485" via pbms tools 2.5.
I have successfully connected to the battery, with normal communication showing. I can change other settings and it successfully saves. I can even change the inverter protocol option to any of the two CAN based options, but if I try to change it to any 485 based option it will not successfully save. I still see a command sent successfully prompt, but the currently selected option in the GUI does not change as it does with the CAN based protocols.
Any idea how to fix this?
