Currently using a JBD 8S 24V 100A Smart BMS.
If the battery is fully charged, the BMS stops charging and discharging. It disconnects the battery from the inverter. I don't want to disconnect the battery.
Your inverter or charge controller settings are incorrect or your cells need to be top balanced. The BMS is only supposed to cut off the battery in extreme conditions to protect the cells from damage due to out of range conditions.
If you can post screen shots of the charger settings and the BMS settings as well as the cell voltages when the BMS cuts off we can give specific recommendations.
