Oceansailor
- Jan 1, 2021
- 4
I noticed when the Battery is fully charged the BMS turns off charging. Now the discharge is on and the current flows through the backfire Diodes of the charge circuit.
The temperature rises....at the end, the discharge switch is turned off by over temperature.
In practical terms: You leave harbour, after a while wind drops and engine is turned on.....now the alternator charges the battery. The BMS is set to 250ah, the batteries can take 300AH. The battery voltage and current are still ok. The BMS turns off because it reached the set 250ah. The BMS turns off the charge cicurit. If current is low just the voltage drops by 0.6 Volts....
Most boaters must have seen this with the common port BMS. Has anybody modified the circurit? I´m thinking of adding a relay into the discharge or add a circuit to stop operation of the DC-DC inverter (DC-DC inverter used for limiting current from alternator).
In bad weather motoring is sometime a whole day...
Wonder about you opinion?
