Jakehound78
- Nov 27, 2022
- 2
So I think this was discussed to some extent but
A. Can’t find it and
B. Don’t know if it was specific to my bms
So I have a JBD SP20S020A for 16s lifepo4 battery. I want to use this on a 13s lithium ion battery and need to change the balance wiring. I attached pics of the BMS. Can anyone help me with wiring diagram (as I said I think someone already sent this) - could you send it again if so.
In its current form, the jst connection ports are set for 16s lifepo4 battery, with bc8-9, bc13-14, and bc17-19 soldered together.. which pins do I need to solder together for this to be used for a 13s battery? I can change the settings to lithium ion in the BMS settings.
Thx in advance for any help.
