JK BMS BT App status page shows "HEAT CURRENT" and I don't have a heater on it.
dfwbmw
DFW
What does heat current on the status page of the BT app mean? I always read 000 and I assumed that is the amount of current used to run a heat pad on the cells but now it is reading something. I don't have a heater or the wiring harness even hooked up.
Thanks
The right column shows heating is off. .358 amps is meaningless. ( especially if you do not have a heater connected.)
I would agree with that but it usually is 0.000 which makes most since. And only when I started charging from a full discharge with 48 amps did I did a number start to come up on this.
Turn charging off and see what happens
I did and it returned to 0.000. When discharging it shows 0.000. So who knows what it is doing. Maybe during charging there is some small amount of amps getting into the heating circuit even though its not in use.
