Is there a trick to getting the JK BMS to accept the voltage you put in for calibration. Keeps saying failed when putting in the actual measured voltage with calibrated DMM which is about 1.1v off from the BMS itself.
Not sure if there is some magic to get this to work but I read another user had similar issues and they could only make marginal changes from what the BMS was measuring only.
