poplarcreek
- Dec 19, 2022
- 2
Hello all,
I have a new system set up with 28 400 watt panels that connect to 2 EG4 6500EX inverters and EG4 LifePower4 batteries. I'm having a difficult time telling on Watch Power how much energy they are producing. I have almost nothing connected to the system yet, and it is off-grid. Watch Power says that it is making 3-5 kWh per day, but it should be making much more than that according to what I'm calculating, I believe. Is this number simply because the system is not using much electricity, and the load is low?
I'm trying to determine if I have a problem out at the PV panel connections, or if this is normal.
Thank you!
Thank you!
