So I am doing calcs with a Growatt 3000W 24v inverter. and 2x 6.0kw batteries (240AH - 6KWH).
I could use some feedback on my calcs/array setup.
15x 290W suntech Panels
Configuration 3s5P.
So the grow watt should handle up to 145Volts. Max solar charge current for growatt says 80Amps.
Is this array too much for the growatt to handle?
and what are the advantages/disadvantages to large arrays or even 2S7P?
Configuration 3s5P.
