OffGridInTheCity
Solar Wizard
In my very 1st few months (6 yrs ago) I had a 7s50p NMC battery on my 1st solar system (200w PV, EPEVER, Reliable Inverter).
I thought - I'll just measure the pack voltages each morning..... don't need a BMS.... but I learned![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
After a few weeks, the morning measurement showed significant different pack voltages at rest. So I started measuring A LOT more and found that some packs were dropping to 2.5v (or lower - who knows?) and then bouncing up to 3.3v after the inverter turned off. Had no clue with 1 measurement (or even several) in 24hrs... over the charge/discharge sequence.
YIKES - a BMS is absolutely needed as one needs to monitor voltages of the lithium-ion cells/packs in series all the time.. when part of an automated charge/discharge application such as a solar system which cannot be done by a human + action (alerts as a minimum, battery current cut-off is good) is valuable based on the measurements if they get out of line - e.g. 2.5v for NMC is not good!.
