mr.palmer
I have 4 pv panels in series connected to victron 150 | 85 mppt smartsolar controller. And charging a 12.8v voltx 200Ah lifepo4 battery. My problem is that even after the victron connect app shows the battery has gone through bulk, absorption and float stages it goes flat overnight with minimal output. This has happened multiple times. I'm using the victron lifepo4 settings on the controller. Now this morning, same issue again but once the sun hits panels and charge flows I also get an error code for over heating. The battery neg cable on the controller got really hot. I have turned off the whole system. Any thoughts.
