oldcartographer
Hello! I am a new member here and to off-grid/solar power systems as well. I have a PowMr 5500w AiO Inverter (POW-HVM5.5K-48V) and a Delong 48v 100Ah battery bank. I don't have solar panels yet, but I am planning to add them soon. I used this guide (https://diysolarforum.com/ewr-carta/lfpprofile/) to set some of the settings for my battery but I am not quite sure about settings 12, 13, and 29 (Please see below).
I have set the following settings in my inverter:
05 (Battery type): User defined
11 (Max. Utility charging current): 20A
12 (Voltage point back to utility): ?
13 (Voltage point back to battery): FUL (battery fully charged)
16 (Charger source priority): CUE (Utility first)
26 (Bulk charging voltage): 58V
27 (Float charging voltage): 54.4V
29 (Low DC cut-off voltage): ?
My battery specification is this:
I understand that the battery can handle a higher charging current than what I have right now but the current setting is sufficient for my use case. If anyone could guide me on setting the correct values for settings 12, 13, and 29, it would be much appreciated.
Thank you.
Thank you.
