^ what he said.You could use them, but I would throw a flat washer underneath it (one with good fit around the stud, not all sloppy and loose)...
Should I remove the black rubber inside the bolt or doesn’t make a difference?You could use them, but I would throw a flat washer underneath it (one with good fit around the stud, not all sloppy and loose)...
It doesn't take much, surprisingly. Nylon nuts are spec'd on a lot of work that I used to do. And I had to constantly tell my new guys not to install them with anything other than hand tools. Because turning them on too fast was enough to weld them in place. Then we had to cut them off, for final adjustments.What’s melting point of nylon? If the terminals get that hot, undoing the bolts is the least of his concern.
Hi you mention bolts and show a picture of nutsHi I lost two of the bolts for my 16s LiFePo4 battery. Are these M6 bolts safe to use? They aren’t flange bolts and have a black rubber lining. The left is what I bought and the right is what came with the cell for comparison.
In general I would use brass over stainless as brass conductivity is 6-7 times better then stainless. Stainless screws also bind into anything not stainless and unlike brass are a real PITA to drill out.Thread pattern should be 6mm x 1.0mm for larger cells. 10mm length should be fine. You can get packs at lowes or Home depot.
If they dont have a length that short 12mm should be ok. As long as it doesn't bottom on with a gap on the top.
You can always cut them down In a pinch. Just mark the legth needed, put a 6mm nut on 1st, make your cut. Then when you take the nut off it cleans up the threads. You can get a 4 1/2 angle grinder at harbor frieght for $10-15. Discs are pretty cheap.
Correct but real life things flow every which way hence I want to give my systems done design headroom , brass does that better then stainlessCurrent goes from battery terminal to bus bars, you shouldn’t be counting on any threaded insert/fastener to provide additional current flow.
