crookedspoon
Hi all,
Often enough, it's said that the cut-off point for a 25.6V (24V) LiFePo4 battery is at 24V to 25V as to not discharge the battery completely.
What I wonder, I haven't easily found an answer to: Does the cutoff voltage value also apply when the battery is under load?
When my battery is at about 27V, then put under heavy load, the voltage easily reaches 25V. Should the load then be removed to avoid damaging the battery should I only consider the voltage when no load is applied?
thanks for your insights!
