tetonmtnbiker
- Jun 9, 2020
- 27
Hello,
I have a Rich Solar 40 Amp MPPT. I cut from their owners manual below. When using the Li battery settings, there are only 3 fields you can adjust. I am considering using "User" to have more control. The problem is, when I look at Will's sticky on LiFePo4 recommended settings I don't see how I should set many of these fields, and there is no "absorption" setting in the Rich Solar parameters so I don't know where to put Will's suggestion on that field.
Alternatively, I could use the SLA and just edit the parameters (they can all be user overridden using bluetooth).
I have a 200Ah Fortune 12V Battery with 2 overkill solar BMS's.
Thanks in advance for any advice.
Jeff
Jeff
Parameters cross-reference table for different types of batteries | |||||
Voltage to set Battery type | Sealed lead-acid battery | Gel lead-acid battery | Open lead-acid battery | Li battery | User (self-customized) |
Over-voltage cut-off voltage | 16.0V | 16.0V | 16.0V | —— | 9~17V |
Equalizing voltage | 14.6V | —— | 14.8V | —— | 9~17V |
Boost voltage | 14.4V | 14.2V | 14.6V | 14.4V | 9~17V |
Floating charging voltage | 13.8V | 13.8V | 13.8V | —— | 9~17V |
Boost return voltage | 13.2V | 13.2V | 13.2V | —— | 9~17V |
Low-voltage cut-off return voltage | 12.6V | 12.6V | 12.6V | 12.6V | 9~17V |
Under-voltage warning voltage | 12.0V | 12.0V | 12.0V | —— | 9~17V |
Low-voltage cut-off voltage | 11.1V | 11.1V | 11.1V | 11.1V | 9~17V |
Discharging limit voltage | 10.6V | 10.6V | 10.6V | —— | 9~17V |
Over-discharge time delay | 5s | 5s | 5s | —— | 1~30s |
Equalizing charging duration | 120 minutes | —— | 120 minutes | —— | 0~600 minutes |
Equalizing charging interval | 30 days | 0 days | 30 days | —— | 0~250D (0 means the equalizing charging function is disabled) |
Boost charging duration | 120 minutes | 120 minutes | 120minutes | —— | 10~600 minutes |
