I am trying to figure out how it works when you have self heating batteries in parallel. The way I understand it is that a self heating battery will only use incoming "charging current" to heat the battery if it is below the safe temperature to charge. So lets say you have 2 of these batteries in parallel. What is to stop the 2nd battery from providing the "charging current" to turn on the heater of the other battery, thereby each battery running down the other battery while trying to heat each other.
