The heat energy is derived from the chargers not the battery itself. If the chargers are configured to inhibit changing at low temperatures then the heating will not occur. Have you considered this may the cause of ithe problem?something as 'self heating' when they don't heat themselves.
The thread I linked above will give you some answers on that.Does the battery charger have a low temp cut off that prevents charging on its own? Is the charger designed to handle a "heater only" load while the batteries warm themselves? or does it stop trying to charge if it sees no big current flowing while attempting to charge? Crazy number of variables here, no way to know what is going on for sure without crazy amounts of trial and error, obviously not fun when its freezing cold.
According to anecdotal evidence it seems the batteries only accept enough current to heat until they are warm enough to accept big charging amps. The tiny internal heaters might take a long time to warm up.
I read the thread you linked. So self heating is actually a pointless misnomer?The thread I linked above will give you some answers on that.
The term “self heating” is a misnomer and marketing gimmick. They can’t heat themselves without an external power source.
Not really. The battery management built into the battery diverts charger energy into the heaters, so in effect is in control of the heating effect. It would be pointless for the battery to use its stored energy for heating. Perhaps 'heating control built in' would be a better description. Consider that the term 'self heating' may have suffered in translation from Chinese.So self heating is actually a pointless misnomer?
Thank you for the very reasonable explanation. Learned a lot from this threadNot really. The battery management built into the battery diverts charger energy into the heaters, so in effect is in control of the heating effect. It would be pointless for the battery to use its stored energy for heating. Perhaps 'heating control built in' would be a better description. Consider that the term 'self heating' may have suffered in translation from Chinese.
Imo if a battery is spending your light producing hours trying to heat itself instead of charging it is pretty pointless.I read the thread you linked. So self heating is actually a pointless misnomer?
Imo if a battery is spending your light producing hours trying to heat itself instead if charging it is pretty pointless.
..there are better options than purchasing a “self” heating unit.
If you get 4 good hours on a negative 20 below zero winters day I doubt you want to spend much of that waiting on batts to heat up.Only a small percentage of the "light producing hours" would be used.
