Hi .
I’ve got a solar system in the process of being sign off by local state inspector .
And he s giving me trouble claiming the compatibility between my inverter ; Outback radian 4048a and flex max charge controller with the new ethos 10.2 kw lithium ion battery ul certified .
Outback says that it is compatible and big battery (the manufacturer ) says as well that it is compatible . Not a close loop but compatible .
What could I do since I have docs that proves it ?
Thank you
Thank you
