I'm located in Ontario and planning to install a hybrid inverter, batteries and eventually solar. My current setup has a separate critical loads panel (240V 30A split phase) with a manual transfer switch and a generator input (L14-30). My average consumption from the critical loads panel is about 1.5 kWH with peaks up to 4.5 kWH. My average daily household consumption is 110 kWH (EVs, hot tub, pool, etc...).
Here are my primary objectives:
1. Keep it relatively simple. I don't need to power my whole house.
2. TOU hydro - peak rates are about $0.30 kWH and lows are $0.03. I'd like to run off battery for 2 kWH * 5 hours during peak rates and AC passthrough otherwise. The AC passthrough needs to support 240V 30A for the critical loads panel.
3. Backup power - I'd like immediate backup power. I have a well pump, sump, fridge and freezer, etc... As per above, the minimum would be for 5 hours, but I can load shed to reduce about 750 WH and extend the run time.
4. Leverage EV battery - I have an EV with a large battery that supports 120V 15A output. I'd like to plug the EV output into the inverter as an input and still maintain 240V output from the inverter. I know I could use a 2 kW DC charger to charge the batteries directly but I'd prefer to connect the EV directly to the inverter.
5. Backup generator - I have a 10 kW generator that I can run off of natural gas. It is not an inverter (again, I could use the DC charger with this). Alternatively, I may switch to a tri-fuel inverter generator.
6. PV - I plan to eventually add solar panels up to 8 kW.
I'm looking for advice on inverter options or suggestions.
I've been looking at the SNRE 10 kW inverter and the Luxpower LXP6K (equivalent to EG4 6000 XP I believe). I could parallel the LXP6K to provide 120V input to one of the inverters but I'd prefer a single inverter if such a system exists.
TIA!
TIA!
