If you have a negative bus bar, you might as well put in a positive bus bar.
You'll want a disconnect between the PV and the solar charge controller. Most of us are using a dual pole DC breaker.
The power from the solar charge controller should be going through the Class T fuse instead of directly to the battery.
The battery disconnect should be on the positive leg coming off of the battery.
Battery (positive) -> fuse -> Switch -> common bus bar (positive)
