Looking for solar installer or electrician who has knowledge of solar in central Michigan area.
doox00
US-MI
I am looking to hire someone that can consult with for a fairly large residential solar install. I already have the panels (72 panels), 3 inverters and diy batteries and plan to do the majority of the install myself but some of it I want to hire out. I would like to hire someone to help with permits I need for pole barn roof install and ground install of panels, I would hire someone to do the pole barn roof install, I will be doing the ground install myself. I am not selling back to the power company but will have grid power used for backup/battery charging when needed, so what permits are needed for this if any as well? I will need 100 amp service wire ran from solar shed to home (buried about ~200 feet run), so need help with this job and permits required if any.
Basically I need someone to consult with install and some of the work hired out as well. I am in Michigan and plan do start this spring/summer.
Thanks!
I can't help with a name but you might be able to ask the head ranger at the Ionia State Recreation Area who installed their system.
