First - battery monitor- look at Victron Smartshunt or BMV712. You want to know how full/empty the batteries are.
Second, highly consider adding a Cerbo (and touch) (or roll your own), to the system. The information you get will be awesome! (Look at some YouTube videos about the Cerbo). It will also let you control the Multiplus from the Cerbo (you won’t need the DSU). This completes the Victron communications.
I think I have read that some people have difficulty sourcing the small MEGA fuses for the Victron distributor. Find the fuses you need (you may need to increase the wire size).
Also, you could get a Victron power In and add fuses (videos on YouTube) - it will save you a few bucks.
One other item you may or may not want to consider is the Victron smart Battery Protects (like BP-65). This can cut power at a certain level, so if you leave stuff on the 12v, it will cut it (at say 12.5v) before draining the batteries all the way down. It depends on how you are going to use it - if it makes sense.
Good Luck.
