Greenan_Energy
- Dec 2, 2019
- 67
Hello, I've just bought 8 *200ah(24V) cells with a bms off RJ Energy that arrived in perfect condition yesterday and looking for some advice.
1. Should I bottom balance them even if the bms will balance them.
2. I'm wanting a charging range between 15% to 85% using a Victron battery protect. With these types of cells what would the upper(85%) voltage range be and lower(15%) range of its a 24V system
3.If I want to charge the battery bank using a Victron 24V 20A charger what setting do I use. I see there is a Li-ion setting, would that work with Lifepo4 or is there a setting that needs to be pre programmed.
Thank you in advance and apprciate any form of advice
