Hi all.
I just switched from lead acid batteries to lifepo4, 2x 280ah in parallel, ooycyoo 60a charge controler and im having problems. Controller set at 13.4 charge (full) and on li setting for lifepo4 and at 12v
The controller shows to get the batterys to 80 - 100% but then it just drops, at 20% i shut it down.
While at about 100% i turned the new inverter on and tryed it out for about 3 minutes to make sure it works.
The batt. Volts dropped to about 50% (3 min @500 watts).
With nothing on but the charge controler i let it charge back up to around 80%
Within about an hour with the c controller still going it dropped to 20%. so at this point i don't know if it's the batterys or charge controler or both :-(
Any help would be much appreciated
