Bluedog225
Texas
- Nov 18, 2019
- 3,268
I’d appreciate some help troubleshooting my very basic set up. I’m going to clean it up and redo my connections with butt once I find my stupid crimping tool. ![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f601.png)
Used panels. The mc4 connectors looked good but who knows.
I tested each of the six panels with a little solar panel tester, and they all seem to be producing within an expected ranges. I’ve hooked them up with two sets of three panels and series and I put the two strings in parallel.
Full Texas sun. Directly overhead. Cool morning. Each leg is producing 4.5 amps but each panel has an lsc of 9.26 amps.
I’ve got 9 A at the combiner box for the two strings. As expected.
This is consistent with what showing on the Cerbo.
38.7 volts with 3 in series=116.1 volts. I’ve got 90 volts. Close enough.
I’m only getting 800 watts. When the theoretical max is 6x275 is 1650 watts.
Where are my missing amps? Is this indicative of something obvious? I wouldn’t think it would be a loose connection in my series or parallel strings cause that would show up differently. Wouldn’t it? Could this be explained by a bad panel? I can take them apart and test them again.
I was curious, if there was any obvious answer to you folks were more electrically inclined.
Thanks
![IMG_0646.jpeg IMG_0646.jpeg](https://diysolarforum.com/data/attachments/216/216338-4e7f01b80b4eafdf3fc4f60aeec86368.jpg)
Thanks
