A handful of people around here recommend low frequency inverters, I wasn't aware of the distinction before joining this forum, and most companies don't seem to push this as a marketing point and most reviews don't mention it. And I've found very few clearly marked low frequency inverters at the small (<2-3kw) end of the spectrum.
I'm wondering, are LF inverters one of those things where the saying "If you don't know if you need one, you probably don't need one" applies?
Can someone ELI5 (explain it like I'm 5 years old), the benefits of LF inverters / drawbacks of HF inverters?
What I have gathered so far:
Pros of LF inverters:
Cons of LF inverters:
- Longevity / reliability
- Higher peak/surge power rating (~200% for HF >300% for LF)
Am I missing anything, are there loads that need or greatly benefit from low frequency, in the same way that some loads require a pure sine wave? Is LF something the average small system builder should even worry about?
- Cost
- Size/Weight
How about efficiency and power consumption at idle, any differences?
If these are the main differences, it seems that priorities would have a lot to do with how much sense it makes to go LF. If you are building an off grid home and designing a system to last 20+ years, where size and weight aren't a big issue and the cost of a LF inverter relative to your overall budget is somewhat small, and your AC demands are higher, LF probably makes a lot more sense. If on the other hand you are building a small mobile system where size and weight matter and where the cost of the inverter will be a big chunk of your budget, LF might make less sense.
Low Frequency inverters tend to handle reactive loads much better. What is a reactive load? One of the best examples are motors or anything that has a motor. That would include refrigerators, saws, compressors, etc. Also any inductive or capacitive load. Any product that has a big intial power surge when starting up will be handled much better by a low frequency inverter. These LF inveters have large transformers that store energy in a magnetic field so when there is a demand for high energy (i.e. motor start-up) the magnetic field around the transformer and/or capacitors in the inverter can step in to help supply the energy needs. So the bottom line is an LF inverter will handle surge loads much better than an HF inverter and ,all else being equal, will be more reliable and last longer in a surge environment. The big transformer in these units is why they weigh so much.
