Thanks guys, 12v is what I need. I have a fairly small battery box that only fits 4@CR260 LA batteries now so I am thinking I series 4 cells each to make 3 each 12.8v batteries. Then Parallel them into 600AH The spec says those batteries are SINOPOLY model SP-LFT200AHA I would like to be able to draw up to a max of 300amps from the pack, which looks like 1/2 of their capability, as they are rated 1C which should allow 600 amps continuous draw if I understand this part.
We currently pull about 250AH from our LA batteries in 24 hours (measured by a Trimetric, soon to be a Victron BMV) I am hoping to get up to 3 days of dry camping from them during minimal solar energy production.
I am still a bit fuzzy on the BMS as Craig said to put them in parallel first. I am looking at 12 cells of 3.2v 200AH.
Is he saying to make 4 batteries @ 3.2v using 3 cells each paralleled connected, and then put those 4 resultant 3.2v "batteries" into a series to make the the 12.8 @ 600ah? How does that help? I am still dcyphering the greek..
I had assumed I would make 3 batteries @ 12.8v (4 cells) then parallel them together. Kind of like buying 12v car batteries and paralleling them together for the higher amprage. (its an example, I am not buying car batteries)
I am hoping to do this only once... My best guess is the BMS is the most likely candidate for failures. Would one be better or three?
How do I size the BMS if I make what I think Craig is suggesting?
So may questions... Sorry.
