So yesterday was the first really sunny weather since we got the battery and PV power was maxed out! And it was staying on the 6-6.5kW range in 3 hours or so until the battery was full. However, someone told me that maxing out PV input on extended periods is bad for the inverter, just like putting the car in red for extended periods. Then again, I read somewhere in this forum to max it out when there is opportunity for it.
Basically I'd like to ask if this is okay or should I limit max PV power? Planning to get another battery soon as well as net metering so I am expecting time on max will probably get longer. Thoughts?
Set-up is currently 7S2P 550w panels. I might change it up to 6S2P.
![IMG_8334.jpg IMG_8334.jpg](https://diysolarforum.com/data/attachments/225/225139-db54cb7f13bbfcb59db8e1113152524f.jpg)
