ToddParker
Hi all.
Sorry if an obvious answer but most solar panels have a ‘male’ MC4 output for positive and ‘female’ for negative. The adapters that come with most power stations that convert MC4 to 8mm/XT60/etc. are set up with the opposite so the polarity is all good: ‘female’ for positive and ‘male’ for negative:
Solar Adapter
+ M —— F +
- F —— F -
If I need a longer run, I have MC4 extension cables but if you wire them up to a solar panel you end up with the male and female being opposite for what you need for the adaptor. I you hook them up the way the cables fit the polarity would be reversed.
Solar Extension Adapter
+ M —— F + —— F+ (Won’t connect)
- F —— F - —— F- (Won’t connect)
So how do people deal with this situation? I could add a second extension cable to get the connectors back to where they need to be but that’s a waste. Is there a male to female adaptor you use in these situations?
Thanks!
Solar Adapter
+ M —— F +
- F —— F -
Thanks!
