Generally speaking, a multimeter has an option to measure internal resistance, or a special battery internal resistance meter can be used to measure it.
Yes ok, the multimeter has the function of measuring the resistance, for example if I wanted to measure a 10 k resistance I use the tester between the resistance terminals, but I don't think you can measure the battery, risking shorting everything.
