KauaiMolokai
- Dec 25, 2019
- 283
Greetings all,
I'm very new to solar and trying to learn as much as I can.
My primary interest will be building, for my own use, more than one "vastly over-powered", off grid system. I plan to mount the panels on a ground rack similar to those used in commercial solar generating farms.
Of course I have 4000 questions. The first one is:
How are the feeds from multiple micro inverters connected? Obviously its AC so a simple series or parallel - as one would do with DC - is not possible. Do micro inverters "talk to each other" to stay "in phase"? Is there a master and slaves system?
My plan would be to connect the outputs from multiple micro inverters together at the rack, and run the resulting 120 or 240 AC line to my house - to replace the grid AC line. This would seem more feasible than running wires able to carry 48V high amp DC (from PV panels without inverters) 300 ft to my building to connect with a large inverter(s).
Thanks. And thanks for all who so generously contribute so much information and knowledge.
