Planning on expanding my PV array and the total voltage of the series based on VOC could be as high as 330v when "cloud edge effect" takes place.
I use a MidNite breaker today (rebadged CBi), MIDEPV15-300, which is rated for 300v limit. Majority of the time the expected voltage will be in the 280-290 range.
https://www.midnitesolar.com/produc...BREAKERS&productCat_ID=16&sortOrder=20&act=pl
I came across this study done by Midnite where they were testing their breakers at 25% above there rating capacity 125v breakers tested at 165v: http://www.midnitesolar.com/pdfs/MidNite_165vdc_ETLtest.pdf
The 2p breaker that I have is stamped with a 250v limit but they added a ETL sticker that ups the limit to 300v.
Any thoughts on the tested vs. rated capacities of the breakers? If I go by their test rating (165v) then I am at the 330v rating (two poles in series).
Wondering though if these could safely handle a higher voltage? Anyone using these in a similar setup?
MidNite's next inline offering is rated at to 600v 4p which would require an extensive redo of my current shutdown and breaker box setup so would like to stay in a 2p scenario.
I could go the mini din rail route and get a breaker rated at 400v or 500v but they don't seem as well built:
https://www.ebay.com/itm/MCB-50A-El...aker-PV-Solar-Energy-Air-Switch-/113277763760
Thanks
Thanks
