Hey all, just got four SPDs for my setup - x1 EG4 6000XP with two PV arrays as input. Typical voltage up to 400V. 48/56V battery array, and AC breaker, no grid tie or grid input.
SPDs - x2 600VDC for the two solar inputs, x1 300VDC for somewhere connecting to the battery (would have liked a 115VDC since it's a 56V max battery setup, so I'm not even sure this SPD will help me?), and x1 300VAC somewhere for my breaker box / inverter.
Few questions..
Few questions..
- The schematics are showing both DC and AC ground wire voltage going to the ground in the AC breaker box. Is that right? With the neutral screw bond in the breaker box, is it ok to set up as such as long as the impedence is lowest on the ground to the exterior ground rod?
- Would the 300VDC SPD serve any purpose here to protect the batteries? My main concern is lightning coming in from the PV lines and surging to the batteries. I'd also have an SPD for the AC in case lightning somehow gets inside via like my minisplit then travels to inverter -> battery that way. Where best to wire the 300VDC if I were to use it? On top of battery box and hooked to the busbars?
