I salvage properties and I lucked into some solar parts including ten 280w panels, a couple 3kw 48v inverters and epever MPPT charge controllers. However no batteries. I'm in AZ and looking to setup a system to "off grid" a standalone AC unit I can use to reduce my cooling costs which are 90% of my electricity bill anyway. What's the minimum setup in terms of battery I could use that would just run the AC units (either window or potentially a mini split) while the sun is out? Or is their a conceivable way to do this without batteries at all?
I don't care about using the system to power anything once sun is off peak. Given that all the parts of the setup are already 48V I wasn't seeing a lot of battery options on the cheap. I expect to use this only though the rest of the hot months before reconfiguring it in a more permanent setup with more panels and different charging hardware and some real battery storage so I'd like to put in as little as possible now.
Thanks so much and I'm really happy Will setup this forum.
