Mixed module sanity check
turkington
Looking to expand my single 165W setup and would like someone to confirm my math adding similar but not the same panels... and sanity check my approach
I currently have a single 165W Furrion module and found that a Renogy 175W has quite similar in specs. I'm planning to add 2x Renogy in series to the Furrion and then parallel a string of 3x Renogy in series for a total of 6x modules in 3s2p configuration. I have a Victron 150/100 MPPT installed already. (Module values below are all for max power)
  • Series 1: 18.72V/8.82A + 17.95V/9.75A + 17.95V/9.75A = 54.6V @ 8.82A (482W)
  • Series 2: 17.95V/9.75A +17.95V/9.75A +17.95V/9.75A = 53.9V @ 9.75A (525W)
  • Both strings in parallel: 53.9V @ 18.6A (1000W) instead of an ideal 1040W.
Does anyone see issues with this? As this is 96% of ideal production and I can reuse the existing panel and fit 5x more 175W modules on my roof I'm leaning towards this solution rather than rip & replace with all the same modules.
Thanks in advance folks -- this community is awesome!
